Working in ArcPro (2.4), I generated contours on a hypothetical surface I created for a grading project. The results didn't appear correct because contours had not generated for all the elevation values. More specifically, a contour line hadn't been created for the top elevation value. I ran the contour tool again in ArcMap (10.3), using the exact same parameters and got different results with a contour line at the highest elevation being generated, which is what I expected to see.
So the question is, what's going here? Using the exact same data with exact same parameters, why would the results be different depending on which version of the software is being used?
