I found that using the default constructor for a ProWindow will generate an object that has its Parent field null. This means using WindowStartupLocation on that object has no effect and the following code doesn't work
var wnd = new ProWindow();
wnd.WindowStartupLocation = WindowStartupLocation.CenterScreen;
wnd.Show();
Is there a way to create a ProWindow object that does have a reference to its parent? Is there an alternative to force WindowStartupLocation?
