Hi All,
I am trying to use Robert Scheitlin, GISP's Popup Panel Widget Version 2.4 to auto-populate a field in the Smart Editor widget. Using a button click, I am able to retrieve the feature's value, as seen on line 16:
_onLoadCreateBoringClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> widgets <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>appConfig<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getConfigElementsByName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'SmartEditor'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>widgets<SPAN class="punctuation token">.</SPAN>length <SPAN class="operator token">===</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>loadSmartEditorInfoNode<SPAN class="punctuation token">.</SPAN>innerText <SPAN class="operator token">=</SPAN> <SPAN class="string token">'Smart Editor is not configured.'</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">var</SPAN> widgetId <SPAN class="operator token">=</SPAN> widgets<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">;</SPAN>
<SPAN
