Greetings,
The fragment below works, cloning GIS content from Portal A to B.
gis2.content.clone_items(data, copy_data=True, search_existing_items=True)
However, the REST URL is copied across ie it has the wrong REST in Portal B.
I read the ESRI article: https://developers.arcgis.com/python/sample-notebooks/using-and-updating-gis-content/
The web map has a number of "values" eg: id, title, url, etc. So I tried to use the method in updating GIS content:
gis2 = GIS(target_portal, username=admin, password=passw, verify_cert=False)
print("LOGGED IN TARGET")
####MAP ID
#map id
search_result = gis2.content.get('4aa844d480704a7392a1bc0b992dee2d')
print("MAP")
display(search_result)
##search_result.layers
#MAP SEARCH
search_result_json = gis2.content.search('title:LQSP', item_type="*")
#display(search_result_json)
#CREATE MAP OBJECT
wm_item = search_result_json[0]
from arcgis.mapping import WebMap
web_map_obj = WebMap(wm_item)
## display(web_map_obj) ### prints map
#DISPLAY JSON
print("WEB MAP OBJ")
web_map_obj.layers
print("DISPLAYS JSON: ")
#display(web_map_obj.layers)
for lyr in web_map_obj.layers:
print(lyr.title + " " + lyr.url)
The section to update the url value is below, this fails??
web_map_obj.update(url='<server>arcgis/rest/services/<map>/MapServer')
I want to update the url from:
<DEV.gov.uk>arcgis/rest/services/<map>/MapServer
TO:
<TEST.gov.uk>arcgis/rest/services/<map>/MapServer
I welcome any suggestions.
Regards,
Clive
