Does anyone know how to fix truncating field values in Survey123. I have a 254 character string field in a hosted feature service that when viewed in the form it is being trimmed to 3 characters (using Survey123 app). In Survey123 Connect I have specified 254 for the length of the string field to match the feature service (btw – editing the feature service in web app does not truncate the field). I have tried deleting and adding the field back but to no avail. Any help is greatly appreciated!
Hi Eric
Just to confirm, when you say the string is being truncated are you referring to an existing string when editing an existing record from the Inbox? Do you receive an error on submit? When submitting the survey does the string get truncated in the feature service, or is the truncation only visible in the form? Could you please provide screenshots and your XLSForm so I can try to reproduce what you're seeing? Also which version of the Survey123 field app and Connect are you using?
Jim
Thanks for your reply Jim; it appears as though the Inbox setting was not functional at last publish (was disabled) which likely was causing the issue. I have enabled and republished and am seeing no issues with field trimming. I appreciate your reply and insight!
Cheers!
Eric-
