I'm wondering if Cascading Select can be used when my Survey is created based on an existing feature layer.
Can I still apply the normal cascading select methodology as when working with surveys not associated to an existing feature layer, given that the domain is generally listed in choices sheet. Does the list in the choices sheet must be the same domain list created first in the referenced feature layer?
Hope my question is clear. Thank you.
Siew Wei
