Our Water Distribution employee using the backflow inspection survey contacted me yesterday about not being able to generate the reports for his survey. I attempted the same and we both get the same error below:
Error occurred when checking the report template. Failed to parse "${F_Devsize2}"Field "${F_Devsize2}" does not exist or cannot be found in current parsing scope.
Previously the reports for this survey were working just fine. There have not been any updates or changes made to the survey itself.
I tried removing the report template and re-uploading it to see if that would make a difference but I still get the same error when trying to generate the report.
The field that the error references is still present in the feature service and the survey itself is functioning normally. Any ideas on what could be causing this?
Thanks!
