I have a survey published with already contains Data. I had several image questions within the form that where not set to required. I would now like to update them to be required. I have downloaded the form va survey123 connect and updated the required field to required = yes for the images in question however when i go to republish the survey i receive the attached Error
"The existing Data service is not compatible with the survey -(request error)"
As a test I have simple tried to republish the form without making any changes to it and i still receive this warning message.
Any ideas as to what is causing this issue ?
