Hello ESRI Team,
I’m trying to get ArcGIS API for Python locally installed on my workstation. My workstation config is as follows:
- Windows 64-bit OS
- Python 27 (which comes along with ArcGIS 10.5.1)
I used the command prompt to navigate to Scripts directory C:\Python27\ArcGIS10.5\Scripts>
pip install arcgis
. I’m getting below error:
C:\Python27\ArcGIS10.5\Scripts>pip install arcgis
Collecting arcgis
Using cached https://files.pythonhosted.org/packages/6e/e3/a0da48d939ac81ac11921a6cd386d98b5c75d75b633a7959d78ae4bfe311/arcgis-1.5.2.post1.tar.gz
Complete output from command python setup.py egg_info:
running egg_info
Running post-install...
No handlers could be found for logger "root"
C:\Python27\ArcGIS10.5\lib\site-packages\setuptools\dist.py:470: UserWarning: Normalizing '1.5.2-post1' to '1.5.2.post1'
normalized_version,
File "<string>", line 1, in <module>
File "c:\users\meghan~1.kul\appdata\local\temp\pip-install-uzcrw5\arcgis\setup.py", line 272, in <module>
setup(**kwargs)
File "C:\Python27\ArcGIS10.5\lib\site-packages\setuptools\__init__.py", line 143, in setup
return distutils.core.setup(**attrs)
File "C:\Python27\ArcGIS10.5\lib\distutils\core.py", line 151, in setup
dist.run_commands()
File "C:\Python27\ArcGIS10.5\lib\distutils\dist.py", line 953, in run_commands
self.run_command(cmd)
File "C:\Python27\ArcGIS10.5\lib\distutils\dist.py", line 972, in run_command
cmd_obj.run()
File "c:\users\meghan~1.kul\appdata\local\temp\pip-install-uzcrw5\arcgis\setup.py", line 120, in run
super().run()
TypeError: super() takes at least 1 argument (0 given)
Command "python setup.py egg_info" failed with error code 1 in c:\users\meghan~1.kul\appdata\local\temp\pip-install-uzcrw5\arcgis\
FYI: I have updated my setup tools. My question is that ArcGIS API for Python not supported with Python 27?
My Best,
Meghan Kulkarni
