I am currently writing a python program to add new monuments to our sde. I am having an issue turning a single row into a feature class. This way I can do a Select by Location on just one section of the map. The issue is the points that I have could be in more than one section. This causes errors on generating the points name. Any tips or tricks to do this?
#------if the fields in the output layer need to be changed do it here------# def convertor(newPoints, outputShape): global newPointsPath, newPointsPath arcpy.env.overwriteOutput = True # arcpy.env.overwrite = True print 'Setting up Schema' #-----This adds all the fields needed for the XY Event Layer to be exactly the same as surveyor.SLCOSU.PLSS_Control_Points---# out = outputShape arcpy.AddField_management(out, "doc_id", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "vault_id", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "security", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "date_added", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "POINT_NAME", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "GRID_ADDRE", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MAILING_AD", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "TOWNSHIP_R", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "SECTION", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "NORTHING", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "EASTING", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "ELEVATION_", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "ELEVATION1", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MAP_SCALE", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "CONVERGENC", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MON_TYPE", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MON_DESCRI", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MON_NOTES", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MON_STATUS", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "GCDB", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "REMARKS", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "COMBINED_S", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "PUBLISH", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "MON_RESET_", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "DATE_DIFF_", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "VERIFIED", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "PLATTED", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "VALIDATION", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "CONTROL_US", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "job_done", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "GEOID_USED", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") #Change back to date later# arcpy.AddField_management(out, "DATE_LAST_", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "LATITUDE", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "LONGITUDE", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "GRID_NS", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "DIR_NS", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "GRID_EW", "DOUBLE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.AddField_management(out, "DIR_EW", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "") arcpy.DeleteField_management(out, ["Field1", "Field2", "Field3", "Field4", "Field5"]) #----Sets up our iterators---# arcpy.MakeFeatureLayer_management(quarterSectionFile, 'ToSelectedQuarters') arcpy.SelectLayerByLocation_management('ToSelectedQuarters', "CONTAINS", out) arcpy.FeatureClassToFeatureClass_conversion('ToSelectedQuarters', output, 'SelectedQuarters') newQuaterPath = output + '\\' + 'SelectedQuarters' quarterSections = arcpy.UpdateCursor(newQuaterPath) quarterSection = quarterSections.next() arcpy.MakeFeatureLayer_management(pointsFile, 'ToSelectedPoints') #----Sets current date to a string----# now = datetime.datetime.now().strftime("%m-%d-%y") #-----This while loop will get the highest point name in the section then assign all default values and known values to the given attribute table----# it = 1 if not quarterSection: print 'nothing selected' print 'Adding Feilds' for quarterSection in quarterSections: highestPoint = 0 #------Gets the highest point name in section-----# arcpy.CreateFeatureclass_management(output, 'TempQuarter') tempQuartPath = output + '\\' + 'TempQuarter' insert = arcpy.InsertCursor(tempQuartPath) insert.insertRow(quarterSection) arcpy.SelectLayerByLocation_management('ToSelectedPoints', "WITHIN", tempQuartPath) arcpy.FeatureClassToFeatureClass_conversion('ToSelectedPoints', output, 'SelectedPoints') newPointsPath = output + '\\' + 'SelectedPoints' points = arcpy.UpdateCursor(newPointsPath) for point in points: if CornerCheck(point.POINT_NAME): continue else: pointName = point.POINT_NAME pointTM = pointName[0] pointM = pointName[1] pointHT = pointName[2] pointTT = pointName[3] pointT = pointName[4] pointH = pointName[5] pointTen = pointName[6] pointO = pointName[7] pointNumber = int(pointTM)*10000000 + int(pointM)*1000000 + int(pointHT)*100000 + int(pointTT)*10000 + int(pointT)*1000 + int(pointH)*100 + int(pointTen)*10 + int(pointO) if pointNumber > highestPoint: highestPoint = pointNumber layerRows = arcpy.UpdateCursor(out) for key in newPoints.keys(): layerRow = layerRows.next() # --This will standardize our data to add into the attribute table---# id = newPoints[key]['id'] northing = newPoints[key]['Northing'] easting = newPoints[key]['Easting'] elevation = newPoints[key]['Elevation'] type = newPoints[key]['Description'].split(' ')[0] northingAddress = newPoints[key]['Description'].split(' ')[1] northingDirection = newPoints[key]['Description'].split(' ')[2] eastingAddress = newPoints[key]['Description'].split(' ')[3] temp = newPoints[key]['Description'].split(' ')[4] eastingDirection = temp.split('-')[0] mon_descript = temp.split('-')[1] Grid_ad = '%s %s %s %s' % (northingAddress, northingDirection, eastingAddress, eastingDirection) Mailing_ad = newPoints[key]['Mailing'] lastshot = newPoints[key]['Date_Shot'] geoid = newPoints[key]['Geoid'] if highestPoint is 0: tempNumber = str(quarterSection.getValue('Area')) + str(quarterSection.getValue('SECTION')) + str(quarterSection.getValue('Quarter_Num')) + str('000') highestPoint = int(tempNumber) highestPoint += 1 tempNum = str(highestPoint) else: highestPoint = int(highestPoint) + 1 tempNum = str(highestPoint) # ----Updates the rows in our atribute table with the values in the dictionary---# layerRow.setValue("doc_id", None) layerRow.setValue("vault_id", None) layerRow.setValue("security", None) layerRow.setValue("date_added", now) layerRow.setValue("POINT_NAME", tempNum) layerRow.setValue("GRID_ADDRE", Grid_ad) layerRow.setValue("MAILING_AD", Mailing_ad) layerRow.setValue("TOWNSHIP_R", quarterSection.getValue('TOWN_RANGE')) layerRow.setValue("SECTION", quarterSection.getValue('SECTION')) layerRow.setValue("NORTHING", northing) layerRow.setValue("EASTING", easting) layerRow.setValue("ELEVATION_", None) layerRow.setValue("ELEVATION1", elevation) layerRow.setValue("MAP_SCALE", None) layerRow.setValue("CONVERGENC", None) layerRow.setValue("MON_TYPE", type) layerRow.setValue("MON_DESCRI", mon_descript) layerRow.setValue("MON_NOTES", None) layerRow.setValue("MON_STATUS", None) layerRow.setValue("GCDB", None) layerRow.setValue("REMARKS",None) layerRow.setValue("COMBINED_S", None) layerRow.setValue("PUBLISH", None) layerRow.setValue("MON_RESET_", None) layerRow.setValue("DATE_DIFF_", None) layerRow.setValue("VERIFIED", None) layerRow.setValue("PLATTED", None) layerRow.setValue("VALIDATION", None) layerRow.setValue("CONTROL_US", None) layerRow.setValue("job_done", None) layerRow.setValue("DATE_LAST_", lastshot) layerRow.setValue("LATITUDE", None) layerRow.setValue("LONGITUDE", None) layerRow.setValue("GRID_NS", northingAddress) layerRow.setValue("DIR_NS", northingDirection) layerRow.setValue("GRID_EW", eastingAddress) layerRow.setValue("DIR_EW", eastingDirection) layerRow.setValue("GEOID_USED", geoid) layerRows.updateRow(layerRow) del newPoints[key] points.reset() arcpy.Delete_management(tempQuartPath) if newQuaterPath: arcpy.Delete_management(newQuaterPath) if newPointsPath: arcpy.Delete_management(newPointsPath) del layerRow, layerRows, quarterSections, quarterSection
Yes, please post the code.
Sorry I am not a gis person. I am a programmer so the terminology is hard for me to fallow some times. I am trying to name a monument (points) based on PLSS sections and quarter sections. The new monuments come in on a csv file. I have created geometry for them. I then do a select by location using these new monuments to select quarter sections that contain these points. I then select the old monuments (from our sde) by the quarter sections. I loop over the old monuments to get the highest point name. I then increment it by one and add that to the new monuments attribute table. The issue happens when the next point in the csv file is in a different quarter section. ALL the old monuments from the selected quarter sections are used causing the point name to be wrong on the next csv point. Does that clear it up? I could add my code if it helps.
I am not sure I understand what you are after... I am guessing that by section you are talking about a PLSS section? Then one monuments (are they points or polygons) could be one or more sections? But they should all be in one feature (row) in the feature class? Or is it that the section geometry is poor so the section polygons overlap each other?
