I have the following Arcade in my symbolisation through AGOL and when I add it, it stops drawing in Explorer.
Is Arcade Symbology not supported in Explorer for ArcGIS yet?
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">.</SPAN>hasfault <SPAN class="operator token">==</SPAN> <SPAN class="string token">'no'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">'greentick'</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">.</SPAN>responsive <SPAN class="operator token">!=</SPAN> NULL<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">'redcross'</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">.</SPAN>highpriority <SPAN class="operator token">!=</SPAN> NULL<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">.</SPAN>lowpriority <SPAN class="operator token">!=</SPAN> NULL<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="string token">'yellowcircle'</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
