I'm trying to open a map located in a project folder, however when i try using this code i get Exception Unhandled error
System.NullReferenceException: 'Object reference not set to an instance of an object.' mapProjectItem was null.
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Collections<SPAN class="punctuation token">.</SPAN>Generic<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Linq<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Text<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> System<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Tasks<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">.</SPAN>CIM<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">.</SPAN>Data<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">.</SPAN>Geometry<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Catalog<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Core<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Editing<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Extensions<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Contracts<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Dialogs<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Framework<SPAN class="punctuation token">.</SPAN>Threading<SPAN class="punctuation token">.</SPAN>Tasks<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">using</SPAN> ArcGIS<SPAN class="punctuation token">.</SPAN>Desktop<SPAN class="punctuation token">.</SPAN>Mapping<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">namespace</SPAN> AddData
<SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">internal</SPAN> <SPAN class="keyword token">class</SPAN> <SPAN class="token class-name">Button4</SPAN> <SPAN class="punctuation token">:</SPAN> Button
<SPAN class="keyword token">protected</SPAN> <SPAN class="keyword token">override</SPAN> <SPAN class="keyword token">void</SPAN> <SPAN class="token function">OnClick</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> mapProjectItems <SPAN class="operator token">=</SPAN> Project<SPAN class="punctuation token">.</SPAN>Current<SPAN class="punctuation token">.</SPAN>GetItems<SPAN class="operator token"><</SPAN>MapProjectItem<SPAN class="operator token">></SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> mapProjectItem <SPAN class="operator token">=</SPAN> mapProjectItems<SPAN class="punctuation token">.</SPAN><SPAN class="token function">FirstOrDefault</SPAN><SPAN class="punctuation token">(</SPAN>mpi <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> mpi<SPAN class="punctuation token">.</SPAN>Name<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Equals</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Map1"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
Map map <SPAN class="operator token">=</SPAN> mapProjectItem<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
ProApp<SPAN class="punctuation token">.</SPAN>Panes<SPAN class="punctuation token">.</SPAN><SPAN class="token function">CreateMapPaneAsync</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
