I cannot figure out how to disable the Minimize and Maximize buttons on a ProWindow. I see the choices for Appearance - Window Style, but even setting it at ToolWindow the Min/Max buttons are still there:
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">controls:</SPAN>ProWindow</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">x:</SPAN>Class</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>RowChanged_TEST.ProWindow<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">xmlns</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://schemas.microsoft.com/winfx/2006/xaml/presentation<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>controls</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>clr-namespace:ArcGIS.Desktop.Framework.Controls;assembly<SPAN class="punctuation token">=</SPAN>ArcGIS.Desktop.Framework<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>x</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://schemas.microsoft.com/winfx/2006/xaml<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>d</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://schemas.microsoft.com/expression/blend/2008<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>mc</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>http://schemas.openxmlformats.org/markup-compatibility/2006<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token"><SPAN class="namespace token">xmlns:</SPAN>extensions</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>clr-namespace:ArcGIS.Desktop.Extensions;assembly<SPAN class="punctuation token">=</SPAN>ArcGIS.Desktop.Extensions<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token"><SPAN class="namespace token">mc:</SPAN>Ignorable</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>d<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">Title</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Tracked Layers<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>470.347<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Width</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>300<SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="attr-name token">WindowStartupLocation</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>CenterOwner<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">ResizeMode</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>CanResizeWithGrip<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Window</SPAN><SPAN class="style-attr language-css token"><SPAN class="attr-name token"><SPAN class="attr-name token">Style</SPAN></SPAN><SPAN class="punctuation token">="</SPAN><SPAN class="attr-value token">ToolWindow</SPAN><SPAN class="punctuation token">"</SPAN></SPAN>
<SPAN class="punctuation token">></SPAN></SPAN>
<controls:ProWindow.Resources>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ResourceDictionary</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<ResourceDictionary.MergedDictionaries>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN><SPAN class="namespace token">extensions:</SPAN>DesignOnlyResourceDictionary</SPAN> <SPAN class="attr-name token">Source</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>pack://application:,,,/ArcGIS.Desktop.Framework;component\Themes\Default.xaml<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
</ResourceDictionary.MergedDictionaries>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>ResourceDictionary</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
</controls:ProWindow.Resources>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Grid</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>ListBox</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">x:</SPAN>Name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>lstLayers<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Margin</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>10,37,10,10<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">BorderBrush</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{DynamicResource Esri_TextControlBrush}<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">FontSize</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>14<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>Label</SPAN> <SPAN class="attr-name token"><SPAN class="namespace token">x:</SPAN>Name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>label<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Map Frame - Layer Name<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Foreground</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>{DynamicResource Esri_TextControlBrush}<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">HorizontalAlignment</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Left<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Height</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>35<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Margin</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>10,2,0,0<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">VerticalAlignment</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Top<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">Width</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>195<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">FontSize</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>15<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">/></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>Grid</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN><SPAN class="namespace token">controls:</SPAN>ProWindow</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any ideas on what might be going on??
