I'm using the conda environment that comes with ArcGIS Pro 1.4 (administrative install in C:\Program Files\ArcGIS\Pro).
So I open a cmd-shell and cd into C:\Program Files\ArcGIS\Pro\bin\Python\Scripts (running as normal Windows user, not as an administrative one).
Creating and listing a new conda env works just fine:
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>conda create --name JebuTest python=3.5
Fetching package metadata: ......
Solving package specifications: .........
Package plan for installation in environment C:\Users\jebu\.conda\envs\JebuTest:
The following NEW packages will be INSTALLED:
pip: 9.0.1-py35_1
python: 3.5.3-0
setuptools: 27.2.0-py35_1
vs2015_runtime: 14.0.25123-0
wheel: 0.29.0-py35_0
Proceed (<Y>/n)?
Linking packages ...
[ COMPLETE ]|##################################################| 100%
# To activate this environment, use:
# > activate JebuTest
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>conda info --envs
# conda environments:
JebuTest C:\Users\jebu\.conda\envs\JebuTest
arcgispro-py3 C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
root * C:\Program Files\ArcGIS\Pro\bin\Python
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN></Y>
As I'm not administrator, the environment installs into my user's home directory.
But if I try to activate the environment, it fails:
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts>activate JebuTest
No environment named "JebuTest" exists in C:\Program Files\ArcGIS\Pro\bin\Python\envs, or is not a valid conda installation directory.<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
Conda info also knows about my user's home directory:
Current conda install:
platform : win-64
conda version : 4.0.11
conda-build version : not installed
python version : 3.5.2.final.0
requests version : 2.11.1
root environment : C:\Program Files\ArcGIS\Pro\bin\Python (read only)
default environment : C:\Program Files\ArcGIS\Pro\bin\Python
envs directories : C:\Users\jebu\.conda\envs
C:\Users\jebu\envs
package cache : C:\Users\jebu\.conda\envs\.pkgs
C:\Users\jebu\envs\.pkgs
C:\Program Files\ArcGIS\Pro\bin\Python\pkgs
channel URLs : https://conda.anaconda.org/esri/win-64/
https://conda.anaconda.org/esri/noarch/
https://repo.continuum.io/pkgs/free/win-64/
https://repo.continuum.io/pkgs/free/noarch/
https://repo.continuum.io/pkgs/pro/win-64/
https://repo.continuum.io/pkgs/pro/noarch/
config file : C:\Program Files\ArcGIS\Pro\bin\Python\.condarc
is foreign system : False<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I can workaround this, by manually setting CONDA_ENVS_PATH to my user's home directory, but that hides the default ArcGIS Pro environment..
Is this a bug in conda itself, a bug in ArcGIS Pro's installation of conda or just wrong usage?
Best Regards
Jens
