This is a topic that's been around for as long as I can remember. The attribute assistant provided a couple methods to do this: autonumber, generate id, and there us a tool called Add Incrementing ID field but it is limited to database tables, not GEOdatabase tables; if an object id is present, the tool won't work.
Is there a method or tool available in ArcGIS Pro 2.4.3 that will autoincrement a field in an enterprise geodatabase table and/or feature class?
