I want to setup a base deployment of Database Server (Workgroup), Portal and Data Store on one server, with Web Adapter(s) on our separate web server.
I've read the "Tutorial: Set up a base ArcGIS Enterprise deployment" here:
This document does a great job of explaining how to deploy ArcGIS Server Enterprise with Portal, Data Store and Web Adapters, especially for a beginner like me, but I haven't found any equivalent guide for the Database Server (Workgroup) scenario.
First, is this possible? If so, is there an install guide for this? Several guides say that ESRI recommends ArcGIS Server, Portal and Data Store all run on different machines, but an exception to this is if you are configuring workgroup ArcGIS Enterprise deployment, but that's as specific as they get. Can't find info about federating a Database Server, or how to create an ArcGIS Server site in Database Server. Also not sure how the Portal connects to the Database Server, is this automatic since they're installed on the same server?
Need advice. Thanks.
