I am trying to create a calculation where i have two measurements:
${measurement_ref} and ${measurement_act}
I have a tolerance set in the field ${measurement_tol}
I calculate the difference ${measurement_dif} in a field by ${measurement_ref}-${measurement_act}
I want a field that tells the user that its Not OK if the difference is outside the tolerance. So far i have created this statement, but it only works if the difference is positive:
if(${measurement_dif} <${measurement_tol}, 'OK', if(${measurement_dif}>${measurement_tol},'Not OK','OK'))
I want the calculation to be able to work with both positive and negative difference values.
Can anyone please assist? 🙂
Another small thing - is anyone aware of an ISBLANK function in xlsforms? I only want to be able to see if its OK or not if there is actually something to be calculated..
