I have converted a CAD file to a shapefile in arc and assigned the shapefile a coordinate system. However when I import the shapefile into arcmap and add a base map the base map will not display and has an x where you should be able to turn on and off the imagery. I am wondering why it is doing this and how I would go about fixing this so the base map will display along with my image. Thank you in advance.
