ArcGIS 10.4, ArcServer 10.4, Federated Portal 10.4, SQL Server 2014 Geodatabase
All these errors give the message Packaging Succeeded, but publishing failed. Yesterday I was getting 001488, and eventually solved the problem by creating a new MXD and copying the layers into it, I was able to publish. This morning I noticed one layer in an already published service wasn't drawing in the web map I added it to. I tried to re-publish the Service and got Errors 001487 & 001369, same error message I was getting yesterday with the other number. I tried a number of things again including creating a new MXD. Nothing worked until I removed the server account privileges from a particular Dataset and then gave the same privileges back to it again. I was then able to re-publish the service.
So my question is what could cause a layer in a service to quit drawing, finally requiring the action I took to remove privileges and reinstate them? Is it possible that if I had renamed one of the Feature layers in the Dataset after initially publishing, this it what it took to fix it?
