Is it possible to return credit usage reports for each user in an Arcgis Online organization using the Python API? And if so, can it be returned for a specific period of time?
The credit manager class just returns the credit usage for the entire organization.
Hi Peter Gamberg,
you can use the following code to check the credits availability for each user:
<SPAN class="comment token">#Checking credits assigned and available to a user</SPAN> api_acc <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>users<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'USERNAME'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="string token">"""When you turn on credit budgeting (using the enable() method), the User object gets additional properties to indicate the assignedCredits and remaining avialableCredits. Thus, you can verify as shown below:"""</SPAN> api_acc<SPAN class="punctuation token">.</SPAN>assignedCredits <SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN> api_acc<SPAN class="punctuation token">.</SPAN>availableCredits <SPAN class="string token">"""As the user continues to use the credits, the availableCredits property can be used to check how much is available for that account. If a user does not have a limit set, then the total available credits in the org become their available credits. The account shown below as not custom limit, hence, it inherits the org's total limit."""</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I have added an idea for this as I was just trying to do this also. Please upvote it here!
Use gis.admin.usage_reports.users(). See the sample @ https://community.esri.com/thread/241589-user-credit-usage?start=0&tstart=0
I have tried using gis.admin.usage_reports.users() and I get strange results. I get a smaller list than what it in our organization and I get lots of names outside of our organization. I can't figure out why its returning such an odd list.
Hi @PeterGamberg1 I know this is an old post but I just wanted to share some info for reference. To create a credit report for users in your ArcGIS Online organization you can create a credit report in ArcGIS Online or similarly in ArcGIS API for Python using gis.admin.usage_reports.credit. You can specify the start time or the timeframe for your report if you need to:
credit(start_time=None, time_frame='week', export=False)
For more details, please see our documentation:
https://developers.arcgis.com/python/api-reference/arcgis.gis.admin.html#agolusagereports
Best,
MJ
