I created a customized ArcGIS Pro module and everything works fine but I also would like to create a customized icon for the module.
I found this resource but it does not work for me
ProGuide Content and Image Resources · Esri/arcgis-pro-sdk Wiki · GitHub
using System.Windows.Media.Imaging;
using System.IO.Compression; //Image is defined as AddinContent.//AddinContent is ESRI custom build action. Cannot use without Addin
BitmapImage forAddinContent = new BitmapImage();
string id = "{49545510-2f4a-4e9c-bc12-3ea79a330fa0}";//From your module
using (ZipArchive zip = ZipFile.OpenRead(
@"C
Users\my_username\Documents\ArcGIS\AddIns\ArcGISPro\" + id +
@\AddinContent.esriAddInX")) {
ZipArchiveEntry zipEntry = zip.GetEntry("Images\AddInDesktop32.png");
MemoryStream ms = new MemoryStream();
using (Stream stmZip = zipEntry.Open())
{ stmZip.CopyTo(ms);}
forAddinContent.BeginInit();
forAddinContent.StreamSource = ms;
forAddinContent.EndInit(); }I get zipEntry = null error
Is there way to customize a module's icon?
Thanks!
