Hi SDK Community!
I am working on an update for our Pro add-in to support performance logging using the PerformanceAndDiagnositcs class. This class is in Pro 2.7, but not prior versions. This means we will need to distribute 2 separate add-ins; one for Pro 2.7 and another for prior versions.
Here is my question: I know the _lowest_ Pro version the add-in will load in can be limited using the desktopVersion attribute in the config.daml file, for example: <AddInInfo id="PerfTools" version="2.7.0.127" desktopVersion="2.1">
I’d like to know if there is another attribute that limits the _highest_ Pro version. If not, can the range be specified in the desktopVersion value? I’d like to be able to use the upper limit for our Pro 2.1-2.6 add-in.
Thanks!
