I am trying to import a Web Appbuilder app into my existing .net core web application. So far, I created a folder in wwwroot, called WebAppBuilder.
All the content from the Web Appbuilder app, I moved to this folder. Then I moved the following files to wwwroot/js
They were originally in the Web AppBuilder folder.
I also added a controller with a view and copied the body from index.html to the view.
ViewData["Title"] = "Index";
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>h1</SPAN><SPAN class="punctuation token">></SPAN></SPAN>Index<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>h1</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="doctype token"><!DOCTYPE HTML></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">http-equiv</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>Content-Type<SPAN class="punctuation token">"</SPAN></SPAN> <SPAN class="attr-name token">content</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>text/html; charset<SPAN class="punctuation token">=</SPAN>utf-8<SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN>
<SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>meta</SPAN> <SPAN class="attr-name token">name</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN>viewport<SPAN class="punctuation token">"</SPAN></SPAN>
