I am using Jupyter Notebooks to automate some AGOL tasks. I have also tested this code in ArcGIS Pro and in Spyder with no luck. All using the same cloned environment. Cloned using ArcGIS Pro.
This specific section of my workflow involves creating offline areas to be used in Explorer for ArcGIS. The layers and maps do not have Editing enabled, but they do have Sync enabled. There are two layers that are Layer Views, each with a definition query applied.
Manually, using the AGOL: Manage Areas interface, I am able to easily draw and create an offline area that is downloadable in Explorer.
However, I cannot seem to get this to work reliably with the Python API.
My notebook:
<SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> GIS
<SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>mapping <SPAN class="keyword token">import</SPAN> WebMap
<SPAN class="keyword token">from</SPAN> arcgis <SPAN class="keyword token">import</SPAN> env
env<SPAN class="punctuation token">.</SPAN>verbose <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN>
<SPAN class="comment token">#sign into gis</SPAN>
gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"My_GIS"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"My_Username"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Successfully logged in as: "</SPAN> <SPAN class="operator token">+</SPAN> gis<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">.</SPAN>user<SPAN class="punctuation token">.</SPAN>username<SPAN class="punctuation token">)</SPAN>
wm_item <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'My_AGOL_Item'</SPAN><SPAN class="punctuation token">)</SPAN>
wm_item
wm <SPAN class="operator token">=</SPAN> WebMap<SPAN class="punctuation token">(</SPAN>wm_item<SPAN class="punctuation token">)</SPAN>
extentdict <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'xmin'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN>x<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'ymin'</SPAN><SPAN class="punctuation token">:</SPAN> y<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'xmax'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN>x<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'ymax'</SPAN><SPAN class="punctuation token">:</SPAN> y<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'spatialReference'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">'wkid'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">3857</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN>
offline_item_properties <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'title'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Re21_App1_North'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'tags'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'Reassessment'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Appraiser'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">}</SPAN>
A1_North <SPAN class="operator token">=</SPAN> wm<SPAN class="punctuation token">.</SPAN>offline_areas<SPAN class="punctuation token">.</SPAN>create<SPAN class="punctuation token">(</SPAN>area <SPAN class="operator token">=</SPAN> extentdict<SPAN class="punctuation token">,</SPAN>
item_properties <SPAN class="operator token">=</SPAN> offline_item_properties<SPAN class="punctuation token">,</SPAN>
folder<SPAN class="operator token">=</SPAN><SPAN class="string token">'Appraiser Maps'</SPAN><SPAN class="punctuation token">,</SPAN>
min_scale<SPAN class="operator token">=</SPAN><SPAN class="number token">160000</SPAN><SPAN class="punctuation token">,</SPAN>
max_scale<SPAN class="operator token">=</SPAN><SPAN class="number token">1500</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>This is almost exactly following the API Reference except that I use an extent instead of a bookmark.
This exact code worked last week. But now it is throwing an error. The error is referencing Line 1755 'layer0_obj' in the _types.py script.
Note: The offline area is created without any packages and is stuck on "Packaging" indefinitely.
Error:
Submitted<SPAN class="punctuation token">.</SPAN>
Executing<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
Start Time<SPAN class="punctuation token">:</SPAN> Friday<SPAN class="punctuation token">,</SPAN> May <SPAN class="number token">29</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2020</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">42</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">58</SPAN> PM
Running script CreateMapArea<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
Completed script CreateMapArea<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
Succeeded at Friday<SPAN class="punctuation token">,</SPAN> May <SPAN class="number token">29</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2020</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">42</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">59</SPAN> PM <SPAN class="punctuation token">(</SPAN>Elapsed Time<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1.22</SPAN> seconds<SPAN class="punctuation token">)</SPAN>
CreateMapArea GP Job<SPAN class="punctuation token">:</SPAN> x_____xTwPeRg5tQfrLowkK0gxr<SPAN class="operator token">-</SPAN>Q<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>x_____xj0aedb71fa5af431ab38f6ae4be4bfd2a finished successfully<SPAN class="punctuation token">.</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN>
UnboundLocalError Traceback <SPAN class="punctuation token">(</SPAN>most recent call last<SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token"><</SPAN>ipython<SPAN class="operator token">-</SPAN>input<SPAN class="number token">-6</SPAN><SPAN class="operator token">-</SPAN>f1b0325e3428<SPAN class="operator token">></SPAN> <SPAN class="keyword token">in</SPAN> <SPAN class="operator token"><</SPAN>module<SPAN class="operator token">></SPAN>
<SPAN class="number token">5</SPAN> item_properties <SPAN class="operator token">=</SPAN> offline_item_properties<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">6</SPAN> min_scale <SPAN class="operator token">=</SPAN> <SPAN class="number token">160000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN> <SPAN class="number token">7</SPAN> max_scale <SPAN class="operator token">=</SPAN> <SPAN class="number token">1250</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token">~</SPAN>\AppData\Local\ESRI\conda\envs\arcgispro<SPAN class="operator token">-</SPAN>py3<SPAN class="operator token">-</SPAN>clone\lib\site<SPAN class="operator token">-</SPAN>packages\arcgis\mapping\_types<SPAN class="punctuation token">.</SPAN>py <SPAN class="keyword token">in</SPAN> create<SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> area<SPAN class="punctuation token">,</SPAN> item_properties<SPAN class="punctuation token">,</SPAN> folder<SPAN class="punctuation token">,</SPAN> min_scale<SPAN class="punctuation token">,</SPAN> max_scale<SPAN class="punctuation token">,</SPAN> layers_to_ignore<SPAN class="punctuation token">,</SPAN> refresh_schedule<SPAN class="punctuation token">,</SPAN> refresh_rates<SPAN class="punctuation token">,</SPAN> enable_updates<SPAN class="punctuation token">,</SPAN> ignore_layers<SPAN class="punctuation token">,</SPAN> tile_services<SPAN class="punctuation token">,</SPAN> future<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">1334</SPAN> enable_updates<SPAN class="operator token">=</SPAN>enable_updates<SPAN class="punctuation token">,</SPAN>
<SPAN class="number token">1335</SPAN> ignore_layers<SPAN class="operator token">=</SPAN>ignore_layers<SPAN class="punctuation token">,</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN> <SPAN class="number token">1336</SPAN> tile_services<SPAN class="operator token">=</SPAN>tile_services<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">1337</SPAN>
<SPAN class="number token">1338</SPAN> <SPAN class="comment token">#----------------------------------------------------------------------</SPAN>
<SPAN class="operator token">~</SPAN>\AppData\Local\ESRI\conda\envs\arcgispro<SPAN class="operator token">-</SPAN>py3<SPAN class="operator token">-</SPAN>clone\lib\site<SPAN class="operator token">-</SPAN>packages\arcgis\mapping\_types<SPAN class="punctuation token">.</SPAN>py <SPAN class="keyword token">in</SPAN> _create<SPAN class="punctuation token">(</SPAN>self<SPAN class="punctuation token">,</SPAN> area<SPAN class="punctuation token">,</SPAN> item_properties<SPAN class="punctuation token">,</SPAN> folder<SPAN class="punctuation token">,</SPAN> min_scale<SPAN class="punctuation token">,</SPAN> max_scale<SPAN class="punctuation token">,</SPAN> layers_to_ignore<SPAN class="punctuation token">,</SPAN> refresh_schedule<SPAN class="punctuation token">,</SPAN> refresh_rates<SPAN class="punctuation token">,</SPAN> enable_updates<SPAN class="punctuation token">,</SPAN> ignore_layers<SPAN class="punctuation token">,</SPAN> tile_services<SPAN class="punctuation token">,</SPAN> future<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">1753</SPAN> <SPAN class="comment token"># LOD that is closest to min scale. Do similar for max_scale.</SPAN>
<SPAN class="number token">1754</SPAN>
<SPAN class="operator token">-</SPAN><SPAN class="operator token">></SPAN> <SPAN class="number token">1755</SPAN> sorted_lods <SPAN class="operator token">=</SPAN> sorted<SPAN class="punctuation token">(</SPAN>layer0_obj<SPAN class="punctuation token">.</SPAN>properties<SPAN class="punctuation token">.</SPAN>tileInfo<SPAN class="punctuation token">.</SPAN>lods<SPAN class="punctuation token">,</SPAN> key<SPAN class="operator token">=</SPAN><SPAN class="keyword token">lambda</SPAN> x<SPAN class="punctuation token">:</SPAN>x<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'scale'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">1756</SPAN> keys <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>l<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'scale'</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> l <SPAN class="keyword token">in</SPAN> sorted_lods<SPAN class="punctuation token">]</SPAN>
<SPAN class="number token">1757</SPAN>
UnboundLocalError<SPAN class="punctuation token">:</SPAN> local variable <SPAN class="string token">'layer0_obj'</SPAN> referenced before assignment<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>If I remove the min_scale and max_scale, the tool runs. But the map area does not have a valid scale and the area is not downloadable in Explorer.
JSON: (with min/max_scale removed and notebook successfully ran)
<SPAN class="string token">"mapAreas"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"mapAreaTileScale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"minScale"</SPAN><SPAN class="punctuation token">:</SPAN> null<SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"maxScale"</SPAN><SPAN class="punctuation token">:</SPAN> null
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> If I go into the AGOL: Manage Areas interface and 'edit' the Level of Detail to where I want it, everything seems to work and the map is downloadable in Explorer.
JSON: (manually editing the Level of Detail in AGOL: Manage Areas interface)
<SPAN class="string token">"minScale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">160000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"maxScale"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1250</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I understand the basic error. The variable is not assigned. The issue is that the error is referencing a script that is not generally modified. If it were my code, it wouldn't be so bad to figure out and rewrite. I believe I am following the API Reference near verbatim, so I am thinking that the issue is potentially with my install, map configs, or somewhere else other than directly in my code.
Is it an issue with my coding or maybe with my notebooks install? Should I try and run a clean Clone and conda? Issue with my map configurations?
What are my options here? Where to begin?
