I am having trouble getting calculations to work in my form. The calculation occurs in a related record that is opened via the inbox. The source for my form is a hosted feature layer in ArcGIS Online. The fields in question are all part of the same record. The Contract field (part of the related record) in my survey has a value when it is opened in Survey123. The values come from a choice list: 1: Asphalt Base road, 2: Concrete Base Road, 3: Sidewalk, 4: Grass. There are four select_one fields that I want to be populated with an answer based on the this contract type. These fields can have an answer of -1: Not Applicable, 0: No, 1: Yes. The contract type will determine how each of these will have their answer calculated. Eventually, I am going to hide the fields that don't fit with a certain contract type. For example, a grass cut does not have vehicle detectors and so would have an answer of -1 (Not Applicable) and be hidden for this contract type. When a field needs an answer, I want each select_one question to not have an automatically calculated answer because I need the user to make a choice. If they don't choose one, it will be caught when then try to submit the form because these fields are required. As I understand it, the calculation should occur every time an answer is changed on my form. That doesn't seem to be happening. When the survey is opened and a field changed, the calculations don't appear to run. If I click the refresh arrows next to the select_one fields nothing appears to happen. I attached my form. Can anyone find anything wrong with my formulas? Am I misusing the calculation column? What am I missing? Thanks.
