I am trying to use the distributed geodatabase tools to archive an SDE database to a file geodatabase on a monthly basis. Workflow is to Export XML Workspace Document from SDE, then Import XML Workspace Document to .gdb. This works fine in ArcMap, but returns an error from ArcPy. I tried creating a ModelBuilder to do this, which works fine, but once exported to ArcPy, fails.
Has anyone else run across this issue? Any ideas on a fix? Thanks in advance!
Error:
Failed to execute. Parameters are not valid.
ERROR 001162: Invalid XML file.
Failed to execute (ImportXMLWorkspaceDocument).
Code:
# -*- coding: utf-8 -*-
# XML_from_ModelBuilder.py
# Created on: 2019-02-12 08:57:39.00000
# (generated by ArcGIS/ModelBuilder)
# Description:
# Set the necessary product code
import arceditor
# Import arcpy module
import arcpy
# Local variables:
Connection_to_arcdb__DJ_operations__sde = "Database Connections\\Connection to arcdb (DJ_operations).sde"
DJ_XML_TEST_zip = "C:\\GIS\\SDE_Archive\\DJ_XML_TEST.zip"
DJ_XML_TEST_gdb = "C:\\GIS\\SDE_Archive\\DJ_XML_TEST.gdb"
DJ_XML_TEST_gdb__2_ = DJ_XML_TEST_gdb
DJ_XML_TEST_zip__2_ = "C:\\GIS\\SDE_Archive\\DJ_XML_TEST.zip"
# Process: Export XML Workspace Document
arcpy.ExportXMLWorkspaceDocument_management(Connection_to_arcdb__DJ_operations__sde, DJ_XML_TEST_zip, "DATA", "BINARY", "METADATA")
# Process: Import XML Workspace Document
arcpy.ImportXMLWorkspaceDocument_management(DJ_XML_TEST_gdb, DJ_XML_TEST_zip__2_, "DATA", "")
