I'm trying to use a select multiple and then ask a subsequent question. I will attach an if statement to the subsequent question so that if "Yes" then another select multiple is shown identical to the previous but I want the choices to the previous to be already selected. Is there anyway to do this?
Hi Bob. Typically you would do this through an expression in the calculation column, but as of version 1.10 it is not possible to calculate select_one or select_multiple types of questions.
Is it possible to use the selected function against the multiple select within the relevant column for the subsequent question?
Yes. You can do something like this for example:
