The following code always returns false, even when true, and the 'AddError' after the 'else' doesn't trigger. When I comment out the 'else:' it works fine, when it's true. The 'except:' doesn't trigger when it's false either? Any thoughts? import arcpy, os, sys stateName = arcpy.GetParameterAsText(0) gisNum = arcpy.GetParameterAsText(1) gisNumStr = "g" + gisNum + ".tif" arcpy.AddMessage("Searching.....") query = "Name = " + "'" + "g" + gisNum + ".tif" + "'" gisName = ("'" + "g" + gisNum + ".tif" + "'") mxd = arcpy.mapping.MapDocument("CURRENT") pdf = arcpy.mapping.ListDataFrames(mxd)[0] vLayer = arcpy.mapping.Layer(stateName) arcpy.mapping.ListLayers(mxd, stateName) try: arcpy.AddMessage("Starting.....") arcpy.AddMessage(gisNumStr) rows = arcpy.SearchCursor(stateName) for row in rows: if row.getValue("Name") == gisNumStr: arcpy.AddMessage(gisNumStr) arcpy.AddMessage(vLayer.name) vLayer.definitionQuery = query arcpy.AddMessage(query) arcpy.SelectLayerByAttribute_management(vLayer, "NEW_SELECTION", query) pdf.zoomToSelectedFeatures() arcpy.RefreshActiveView () arcpy.SelectLayerByAttribute_management(vLayer, "CLEAR_SELECTION") arcpy.RefreshActiveView () arcpy.AddMessage("Search completed..........") del mxd, pdf, vLayer, query, row, rows else: arcpy.AddError("Item does not exist"); sys.exit() del row del rows except: arcpy.AddError("No");sys.exit() del row del rows
