Hello everyone,
How can I create a point feature in a feature class with ArcPy the same way I do it with vb.net
I need to convert this vb.net code into Python code.
Dim workspaceEdit As IWorkspaceEdit = CType(myTargetIWorkspace, IWorkspaceEdit)
'' Start an edit session. An undo/redo stack isn't necessary in this case.
workspaceEdit.StartEditing(False)
''/ Start an edit operation.
workspaceEdit.StartEditOperation()
Dim feature As IFeature = pFeatureClass.CreateFeature()
feature.Shape = pPoint
feature.Value(feature.Fields.FindField("ID")) = IncidentID
feature.Value(feature.Fields.FindField("ADDRESS")) = Address
feature.Value(feature.Fields.FindField("XCOORD")) = pPoint.X
feature.Value(feature.Fields.FindField("YCOORD")) = pPoint.Y
feature.Value(feature.Fields.FindField("PROBDESC")) = ProblemDescription
feature.Value(feature.Fields.FindField("REQSTDATE")) = DateTime.Parse(RequestedDate.ToString)
feature.Store()
''// Save the edit operation. To cancel an edit operation, the AbortEditOperation
''// method can be used.
workspaceEdit.StopEditOperation()
''// Stop the edit session. The saveEdits parameter indicates the edit session
''// will be committed.
workspaceEdit.StopEditing(True)
