I am currently running ArcMap 10.5.1. I have been experiencing an issue related to any basemap data, such as World Imagery or Streets. If I add a basemap layer to a map, when I try to edit any shapefile I cannot see the edits I am making until I refresh the map or pan and wait for the basemap to refresh. Also, if I turn off the basemap layer in the Table of Contents, I cannot pan the map or make the map update until I turn the layer on again in the TOC. If I remove a basemap layer, I have to save the map, close it, and then reopen it to be able to pan around or do anything in the map. Adding the basemap layer back into the map results in the previously described issues reoccurring.
I am working on a new computer (Intel i7-7820HQ CPU @ 2.90GHz, 32.0 GB RAM, 64-bit Windows 10 Pro Operating System, 1 TB hard drive) and a fresh installation of ArcMap 10.5.1. I did not change any options that have caused this issue, as far as I can recall, and IT said they installed a vanilla version. IT at my company optimized my computer for performance and no improvement occurred. We also tried reinstalling ArcMap to see if that would fix the issue and it did not. I have a coworker that has the same computer as I do and he is not experiencing this issue. I am wondering if there are any options I should try to fix this issue.
