I have a select_one question with 5 potential responses. I have a corresponding integer question that is filled in based upon the results from the select_one. I have a calculation on the integer question that either returns a 0 or nothing depending on the select_one. If the calculation is 0, worker moves on, if the field is blank from the calculation, then the worker is required to add a value greater than 0. Can i add a constraint to the integer field only when the calculation returns 'blank'?
--gary
