Hi. Does anyone know how to remove a field created through an attribute expression from the table in a saved web map or through the feature layer visualization? I've got several derived fields for popup formatting that I do not want to appear in the table. But even if I have them unchecked in the attribute configuration they still show up.
Thanks.
Hi Mary Ellen,
You can hide fields in the web map attribute table through the Item Details > Visualization > Configure pop-up dialog > configure attributes > hide the desired fields > OK > OK > Save Layer. Then reload the web map and open the attribute table and you should see that the fields are hidden.
Hope that helps,
-Peter
