{"error":{"code":400,"message":"Unable to complete operation.","details":["Unable to apply edits"]}}
Bug NIM-088473 : Unable to edit reprojected data that participaties in a geometric network in a feature service ?!!?
Bertrand L.
I ran FL.isEditable(), and it is returning that it is editable. However, I still get the:{"error":{"code":400,"message":"Unable to complete operation.","details":["Unable to apply edits"]}}when I attempt the save. Pointing the FL to a feature class outside of a geometric network allows me to save the edits. 😞
By the way you can use FeatureLayer.isEditable() method to find out whether it is editable or not.
Is it possible to edit a specific feature class that is contained in a geometric network via the AGS JSAPI? I am attempting to edit a point feature class (Lift Stations) that are part of our Sewer Network. I have all of the layers loaded into the .mxd, and can edit this layer inside of ArcMap; however, when I publish this layer to ArcGIS Server and attempt to edit this layer I get an error (via Firebug): {"error":{"code":400,"message":"Unable to complete operation.","details":["Unable to apply edits"]}}I did a test, and exported this layer to a stand alone feature class outside of the geometric network, and the same code works. I can edit just fine...I have it set up so that the users can only edit the attributes, and can not move the points.Any help is greatly appreciated!
