Hello everyone,
I have the following questions for the workforce:
And if there is a tech support that i can contact please let me know.
Thank you in advance
Hello Ali,
Hello Ali, thanks for your feedback on Workforce.
1. No, at this time it is not possible to change the app design.
2. No, it's not possible to change the fields that are displayed in the web or mobile app. Can you provide some information on why you'd like to change the fields and what you'd like to add or remove?
3. Yes, it will be possible to remove Navigator from the available apps; for the 1.0 release we have an App Integration experience that allows you to configure which ArcGIS app (Navigator, Collector or Survey123) to use with your project. Which other apps are you considering adding?
4. Yes, there's a few ways you can do this. You can use ArcGIS Pro to edit the Assignments feature service in the same way you'd edit any other feature service. You need to make sure that you follow the guidelines for how to create assignments; The Workforce Schema. You can use a script to import assignments into the feature service; we've created several that you can use as a starting point: workforce-scripts
Similar questions to were posted to the Workforce Beta forum but included a few additional questions; please let me know if you'd like to continue the discussion there.
thanks,
Craig
Hi @cmerwin
This is not possible in Workforce today. It is something we could support when Workforce moves into Field Maps; as we're looking to open up more control for the Project Owner with how the Assignment information is displayed.
Craig,
Is it possible to change the format of the due time from for example to something that shows the full due date and time? We are transitioning our City Inspector over to workforce and when our dispatchers schedule inspections, they need the ability to see the due dates and times. Any ideas?
Any assistance would be greatly appreciated!
-Cody
I would like to have someone fill out a geoform (public) for a new meter install request. Which will use the same assignment feature class as a workforce project. For example, adding 3 fields in the details section for workforce to include Permit #, Tap Size requested, Rate Class(commercial, irrigation, industrial, etc). The worker would then be able to see the assignment with appropriate information from the requester and open Collector to update the Meter data during install.
Thanks Ali, thanks for following up. A couple follow-on questions:
I agree that you want to the Worker to be using the right web map or survey for their work; but it's not a use case we've come across where a single Workforce Project uses Collector and Survey123.
Examples of your project and the scenarios you're trying to solve would really help to dig into this.
thanks, Craig
sure!
for example, lets say i have 4 assignments
Assignment 1: uses webmap1 in collector
Assignment 2: uses webmap2 in collector
Assignment 3: uses survey1 in survey123
Assignment 4: uses survey2 in survey123
i give a worker assignment1, i want this mobile to directly open webmap1 in collector without giving him the option to go to another webmap.
if i give him assignment4, he should directly go to survey2 in survey123.
it might be risky that the worker open another webmap or survey by mistake.
This will help us avoid any misunderstanding or confusion between dispatcher and worker.
Ali,
Hello again,
I have some additional questions if its okay:
Thank you very much.
Regards,
Ali
Thanks for clarifying on the request to add/remove fields. What we're hearing from users is that; while they first want to add or remove fields from the Assignment feature service and have that reflected in the web and mobile apps; once they realize that they can launch Collector from Workforce; that handles the majority of scenarios where they want to customize or change the Assignments feature service.
There definitely are valid use cases for adding fields to the Assignments feature service and have them appear; that's in our backlog for a future release. If you have examples like this, please pass them along so I can add them to our backlog.
Thanks for the comments, glad you enjoyed the session on Workforce and looking forward to hearing your feedback after it's release.
Dear Craig,
There is no particular reason for adding/removing fields, im just thinking about future projects where some people would like to have only specific fields to describe their assignments and not all of them.
Thank you very much for your useful answers.
Btw, I attended the dev summit in palm springs few months ago, and your presentation on workforce was my favorite, it was very interesting.
Since that moment i started working on workforce and started trying different cases.
I will try some additional stuff and i'll get back to you if needed.
Thanks again
Can you provide some more information on why removing the Priority field is a use case? If left empty; it will not appear to field workers. Can you provide some use cases or more information on what additional fields you would like to add?
My replies to your 2 other questions
Thank you very much Craig for your helpful reply.
for number 2, for example i want to remove the priority field or add any other field needed. it would be much better if these fields were flexible.
also i have 2 extra questions:
Thanks again for your kind help!
