I have a workflow in which I obtain lat/long from .jpg pictures taken with a drone and obtain an array of multiple lists in which I have the lat and long values. I am thinking of iterate the array, create points using arcgis.geometry.Point method and plot those points in the map object created before. I`m not sure if I should, somehow, create graphics from those points or I should create a feature inside my account and insert the point values as records in the feature and after that add the feature into the map as a layer?
Ionut
