I've written a Python script that pulls a bunch of feature classes out of SDE into a file GDB on my C: drive, performs a bunch of analysis, then creates a new version on SDE (a child of default), puts the analysis results in the database, reconciles, posts, etc...This line:arcpy.CreateVersion_management(DefaultSdeGDB, "sde.DEFAULT", VersionName, "PROTECTED")
used to work fine, but something must have changed somewhere because suddenly the CreateVersion tool fails with the following messages:arcpy.CreateVersion_management(DefaultSdeGDB, "sde.DEFAULT", VersionName, "PROTECTED")
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 9192, in CreateVersion
raise e
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000837: The workspace is not the correct workspace type.
WARNING 000379: The value may not be valid because of empty domain or does not exist in the domain
Failed to execute (CreateVersion).
The "DefaultSdeGDB" variable is a reference to a connection file in ArcCatalog's "Database Connections" folder, and it works when creating references to feature classes earlier in the script. And it used to work in this function as well.This happens regardless of whether I'm pointing at our production database or testing database (but they're on the same machine and they're both still running 9.3 while 10 is on my desktop--but that didn't create a problem earlier). If I delete all the earlier code from the script and run it again (starting with "CreateVersion..."), it works fine. With that in mind, I've tried setting the "DefaultSdeGDB" variable to 'None,' waiting five seconds, resetting the variable, and retrying the version creation; but that doesn't work either.Any other ideas? Thanks in advance.Dan
