Hi everyone,
I am trying to use the .split() function on a string and keep gettings errors. The field is the popup information from a converted KMZ and is called PopupInfo. The code I am trying to use is:
!PopupInfo!.split("<br>")[14]
but am getting Error 000539 and is saying "IndexError: list index out of range". The calculation will run fine if 14 is swapped out for 0 or -1 to get the first or last section. I am counting 27 sections if it is being broken at each "<br>". I've tried finding and replacing all of the <br>'s with a dash or underscore but the calculation still fails with anything other than 0 or -1. The text string that I am trying to pull from looks something like this:
US20 EB <br> <br> FID 57 <br> RampDate 9/30/2013 <br> RouteId 161 <br> RouteName US20 EB <br> TownId 314 <br> TownName Watertown <br> IsMissingR False <br> IsMissingS False <br> IsMissingC True <br> InspNotes <br> DistrictId 6 <br> LegacyID 335 <br> status 6 <br> StatusText Deficient <br> DstrctRank 669 <br> deficient -1 <br> GlobalID {C4BBAA58-9DFE-4953-AC74-FF3448002388} <br> created_us <br> created_da <br> last_edite DAVID.DINOCCO <br> last_edi_1 10/17/2017 <br> ReInspectn 0 <br> AssetID <br> ProgNotes <br> Rank 669
I would be trying to field calc a different field with the LegacyID from this PopupInfo. Is there a problem with this string that is causing the index errors? The lengths at both ends are never the same so I can't trim off the ends.
Thanks for the help!
Tim
