I'm using the Tax Parcel Viewer and am trying to get the initial extent to fall where I want it when the map loads. To help me figure out what's going on I'm using the following listener:
var mapExtentChange = map.on("extent-change", changeHandler);
And
function changeHandler(evt) {
var extent = evt.extent,
zoomed = evt.levelChange;
alert('you moved');
This event fires 3 times while map is loading. When I use previous extent button, I can see what the previous extents were and it makes no sense.
How can I figure out what is making the extent-change fire three times when the map is initially loading? All this loading seems like a poor use of resources. Thanks.
