I have a script that is creates a buffer around points, converts the round buffers to squares, clips a road layers with the square, then calculates the length for the clipped roads and exports data to a csv file. I have run this script before and it took roughly 3 days to complete. This time when I ran the code it's projected to take a month to mine the data. I have no idea why it might be slowing down and could really use some help figuring this out. Does anyone know how I could speed up this process?
# -*- coding: utf-8 -*-
# 2_TrapStatsAndFloatingRoadDensity.py
# Altered on: 2015-6-2 10:00 am
# Created by: L.M.Blackburn
# ArcGIS 10.1
# Notes: iterates thru orders shapefiles and creates a buffer
# around each point. The round buffer is converted to a feature envelope
# which makes a square polygon around the point. This square is used to
# clip the roads layer. Then I calculate length for the clipped roads by adding
# a field and calculating geometry. Run statistics to get the sum length
# of roads in each square. export sum length, block name, centroid of
# square out to a text file
# (2nd script for 4th part of analysis)
# Needed data: Order sublayer from VRP
# List of fields to drop
# Roads network to get length data
# Import arcpy module
import arcpy, os, sys, traceback, csv
# Set the necessary product code
import arceditor
import arcinfo
# Set workspace environment - this is where the solved route layers are located
arcpy.env.workspace = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\Orders\\'
# --------------------Set local variables ------------------
# ---workspace for order layers
ordersLyr = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\Orders\\'
# ---workspace for buffer layers
bufferLyr = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\Buffers\\'
# ---set default buffer distance
bufDefault = "6000 Meters"
# ---workspace for envelope layers
envelopeLyr = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\Envelopes\\'
# ---workspace for route layers
routeWkspc = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\Routes\\'
# ---set workspace path for clipped roads
outDataPath = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\ClipRoads\\'
# ---set road layer - for use in clip & length
Road = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\RoadsForSnap\\SDC Edge Source.shp'
# ---fields to delete from Orders layers
dropFields = ["Descriptio", "ServiceTim", "TimeWind_1", "TimeWind_2", "TimeWind_3", "TimeWindow", "MaxViolati", "MaxViola_1", \
"PickupQuan", "DeliveryQu", "Revenue", "SpecialtyN", "Assignment", "RouteName", "ViolatedCo", "CumulTrave", \
"CumulDista", "CumulTime", "ArriveCurb", "DepartCurb", "DepartTime", "WaitTime", "ViolationT", "CumulWaitT", \
"CumulViola", "ArriveTime", "SourceID", "SourceOID", "PosAlong", "SideOfEdge", "CurbApproa", "Status"]
try:
print 'Opening CSV file...'
# Step 1 - Create table for output data
# Needed fields: From script [Block, Scale, Sequence, FromPrevTr, FromPrevDi, totTime, totDist, x, y, totalRdLength]
CSVFile = 'F:\\Workspace\\Sandy\\GM_costAnalysis\\analysisMay15cont\\AllTrapsData_June2.csv'
f = open (CSVFile, "wb")
w = csv.writer(f, delimiter=',', lineterminator='\n')
fieldNames = ['Block', 'Scale', 'BufferType', 'Sequence', 'FromPrevTr', 'FromPrevDi', 'x', 'y', 'bufferDist','totTime', \
'totDist', 'totalRdLength', '\n']
w.writerow(fieldNames)
# Step 2 - Loop through files in orders folder
# Create variable to hold orders feature class files
orderList = arcpy.ListFiles("*.shp")
# Loop through layers & break name into segments to be used when naming orders lyrs
print 'Creating Buffers...'
for shp in orderList:
lyrs = arcpy.mapping.Layer(ordersLyr + shp)
splitName =shp.split('_')
block = splitName[0]
scale = splitName[1].rstrip('.shp')
# define buffer distance
if scale == "1K":
bufDist = "1000 Meters"
elif scale == "2K":
bufDist = "2000 Meters"
elif scale == "3K":
bufDist = "3000 Meters"
elif scale == "4K":
bufDist = "4000 Meters"
elif scale == "6K":
bufDist = "6000 Meters"
elif scale == "500":
bufDist = "500 Meters"
else:
bufDist = bufDefault
print 'Order: ' + shp + ', Buffer: ' + bufDist
# Jump into orderLayers to delete unneeded fields & add XY
arcpy.DeleteField_management(shp, dropFields)
arcpy.AddXY_management(shp)
# Step 4 - Run buffer on order layers
arcpy.Buffer_analysis(shp, bufferLyr + 'buf' + '_' + block + '_' + scale, bufDist, 'FULL', 'ROUND', 'NONE', '#')
arcpy.Buffer_analysis(shp, bufferLyr + 'buf2' + '_' + block + '_' + scale, bufDefault, 'FULL', 'ROUND', 'NONE', '#')
bufferList = []
for dpath, dnames, fnames in arcpy.da.Walk(bufferLyr, datatype = 'FeatureClass', type = 'Polygon'):
for files in fnames:
bufferList.append(os.path.join(files))
# Step 5 - Run feature envelope to polygon on buffer layers
print 'Converting round buffers to squares...'
for bufShp in bufferList:
bufSplitName = bufShp.split('_')
blockID = bufSplitName[1]
scaleID = bufSplitName[2].rstrip('.shp')
bufID = bufSplitName[0]
print 'Buffer: ' + bufShp + ' Block: ' + blockID + ' Scale: ' + scaleID + ' BufferType: ' + bufID
arcpy.FeatureEnvelopeToPolygon_management(bufferLyr + bufShp, envelopeLyr + bufID + '_' + blockID + '_' + scaleID, 'SINGLEPART')
# Step 6 - Calculate totalTime and totalDistance using insert cursor
# loop through each record in the table - calculate values and...
# use selected features to clip roads layer & calculate geometry
# add values to the CSV table
print 'Populating CSV file...'
envelopeList = []
for dirpath, dirnames, filenames in arcpy.da.Walk(envelopeLyr, datatype = 'FeatureClass', type = 'Polygon'):
for filename in filenames:
envelopeList.append(os.path.join(filename))
for eLayer in envelopeList:
eLayerName = eLayer.split('_')
blockEID = eLayerName[1]
scaleEID = eLayerName[2].rstrip('.shp')
bufEID = eLayerName[0]
print 'eLayer: ' + eLayer + ' Block: ' + blockEID + ' Scale: ' + scaleEID + ' BufferType: ' + bufEID
eLyrPath = envelopeLyr + eLayer
#Make a layer from the feature class - needed for selecting records to be used in the clipping
arcpy.MakeFeatureLayer_management(eLyrPath, "clipLayer")
# use search cursor to grab data row by row to populate CSV file
with arcpy.da.SearchCursor(eLyrPath, ("Sequence", "FromPrevTr", "FromPrevDi", "POINT_X", "POINT_Y",
"BUFF_DIST")) as cursor:
for row in cursor:
dataList = []
dataList.append(str(blockEID))
dataList.append(str(scaleEID))
dataList.append(str(bufEID))
dataList.append(str(row[0]))
dataList.append(str(row[1]))
dataList.append(str(row[2]))
dataList.append(str(row[3]))
dataList.append(str(row[4]))
dataList.append(str(row[5]))
n = int(row[0])
sN = "=" + str(n)
n2 = n +1
sel = "=" + str(n2)
prevTime = float(row[1])
prevDist = float(row[2])
# print sN
postTime = ""
# use a nested search to get values for total time and total distance
# there are some cases where the below expression will be false in that
# event we will need to cacluclate the distance to the depot or just leave
# the values for prevTime & prevDist as place holders, otherwise I end up with
# road length being written in the wrong field
expression = arcpy.AddFieldDelimiters(eLyrPath, "Sequence")+ sel
for row2 in arcpy.da.SearchCursor(eLyrPath, ("FromPrevTr", "FromPrevDi"), expression):
postTime = row2[0]
totTime = prevTime + float(postTime)
# print totTime
dataList.append(str(totTime))
postDist = row2[1]
# print postDist
totDist = prevDist + float(postDist)
# print totDist
dataList.append(str(totDist))
# if above for loop yeilds no results, calculate postTime and postDist differently
# grab DepotVisits layer - if VisitType = "End" then grab values for "FromPrevTravelTime" & "FromPrevDistance"
if postTime == "":
#select corresponding route layer file and grab sublayer: DepotVisits
print "extracting time & distance to Depot"
routeLyr = arcpy.mapping.Layer(routeWkspc + "TrapRoute_" + blockEID + "_" + scaleEID + ".lyr")
if routeLyr.isGroupLayer:
for sublyrs in routeLyr:
# print sublyrs.name
if sublyrs.name == 'Depot Visits':
arcpy.MakeFeatureLayer_management(sublyrs, "depotVisits")
qLast = "= 2"
expression2 = arcpy.AddFieldDelimiters("depotVisits", "VisitType")+ qLast
for row3 in arcpy.da.SearchCursor("depotVisits", ("FromPrevTravelTime", "FromPrevDistance"), expression2):
postTime2 = row3[0]
totTime2 = prevTime + float(postTime2)
# print ("Depot Visit Time: {0}, {1}, {2}".format(prevTime, postTime2, totTime2))
dataList.append(str(totTime2))
postDist2 = row3[1]
totDist2 = prevDist + float(postDist2)
# print ("Depot Visit Distance: {0}, {1}, {2}".format(prevDist, postDist2, totDist2))
dataList.append(str(totDist2))
# select single record to use when clipping - this selection must be on a layer not fc
# always create where clause using AddFieldDelimiters
seqField = "Sequence"
where_clause = arcpy.AddFieldDelimiters("clipLayer", seqField)+ sN
arcpy.SelectLayerByAttribute_management("clipLayer", "NEW_SELECTION", where_clause)
# Clip roads w/ selected polygon - for this I will need a search cursor
clipRoads = outDataPath + 'rdsClip_' + blockEID + '_' + scaleEID + '_' + bufEID + '_' + str(n)
arcpy.Clip_analysis(Road, "clipLayer", clipRoads)
clipRoadsShp = clipRoads + ".shp"
# Use geometry/length to get the total length of clipped roads(in meters)
g = arcpy.Geometry()
geometryList = arcpy.CopyFeatures_management(clipRoadsShp, g)
length = 0
for geometry in geometryList:
length +=geometry.length
# append length (meters) at end of line to csv dataList
dataList.append(str(length))
# dataList.append('')
# print length
# Write dataList to csv file ---- may need to dedent this one more time ---
w.writerow(dataList)
# print dataList
print 'Script complete'
f.close()
except:
if arcpy.Exists(CSVFile):
print 'Data written in CSV file'
f.close()
print 'Program failed.'
print 'Check python errors.'
tb = sys.exc_info()[2]
tbinfo = traceback.format_tb(tb)[0]
pymsg = "PYTHON ERRORS:\nTraceback Info:\n" + tbinfo + "\nError Info:\n " + str(sys.exc_type) + ": " + str(sys.exc_value) + "\n"
msgs = "ARCPY ERRORS:\n" + arcpy.GetMessages(2) + "\n"
arcpy.AddError(msgs)
arcpy.AddError(pymsg)
print msgs
print pymsg
arcpy.AddMessage(arcpy.GetMessages(1))
print arcpy.GetMessages(1)
# print ("Points to select: {0}, Radius: {1}".format(centroidPath, radius))
