Hi,I modified (simplified) the OfflineEditingSample to try and generate a geodatabase from one of our Feature Services. I'm just trying to generate the geodatabase file and download it. Once I have that working I can move on to more fun stuff. Here is the code (lifted from the sample): AGSGDBGenerateParameters *params = [[AGSGDBGenerateParameters alloc] initWithFeatureServiceInfo:self.gdbTask.featureServiceInfo]; params.extent = self.mapView.visibleAreaEnvelope; params.outSpatialReference = self.mapView.spatialReference; NSArray* layers = @[@(1)]; // Just getting one layer for testing params.layerIDs = layers; [SVProgressHUD showWithStatus:@Preparing to download]; [self.gdbTask generateGeodatabaseWithParameters:params downloadFolderPath:nil useExisting:YES status:^(AGSResumableTaskJobStatus status, NSDictionary *userInfo) { //If we are fetching result, display download progress if (status == AGSResumableTaskJobStatusFetchingResult) { NSNumber* totalBytesDownloaded = userInfo[@AGSDownloadProgressTotalBytesDownloaded]; NSNumber* totalBytesExpected = userInfo[@AGSDownloadProgressTotalBytesExpected]; if(totalBytesDownloaded != nil && totalBytesExpected != nil){ double dPercentage = (double)([totalBytesDownloaded doubleValue]/[totalBytesExpected doubleValue]); [SVProgressHUD showProgress:dPercentage status:@Downloading features]; } } else { //don't want to log status for "fetching result" state because //status block gets called many times a second when downloading. //we only log status for other states here NSLog(@Status: %@", AGSResumableTaskJobStatusAsString(status)); } } completion:^(AGSGDBGeodatabase *geodatabase, NSError *error) { if (error) { NSLog(@error generating geodatabase: %@", error); [SVProgressHUD showErrorWithStatus:@Error downloading features]; } else { NSLog(@downloaded geodatabase: %@", geodatabase.path); [SVProgressHUD showSuccessWithStatus:@Finished downloading]; } }];Several status events are logged and eventually the completion block fires with an error. The NSLog output to the console looks like this:Status: Waiting for default parameters Status: Pre-processing job Status: Starting job Status: Polling Status: Polling Status: Polling Status: Polling Status: Polling Status: Done error generating geodatabase: Error Domain=NSCocoaErrorDomain Code=400 "The operation couldn???t be completed. " UserInfo=0x14f4f860 {NSURL=http://xyz:6080/arcgis/rest/services/ElectricDistribution/FeatureServer/jobs/j51fbc2858ae648d89478daa6bd27b32b?f=json, responseJSON={ error = { code = 400; description = ""; }; lastUpdatedTime = 1399335065000; replicaName = "Ags_Fs"; resultUrl = ""; status = Failed; submissionTime = 1399335050000; }, NSLocalizedFailureReason=}Note: I replaced the location of the server in the error message with xyz. It is hidden behind a firewall and access is occurring over a VPN.Can anyone shed some light on the error message. It's not telling me much.Also note: here are the Sync Capabilities on the Feature Service:Sync Capabilities: Supports Registering Existing Data: true Supports Sync Direction Control: true Supports PerLayer Sync: false Supports PerReplica Sync: true Supports RollbackOnFailure : false Supports Async: true
Thanks in advance,James
