Hello everyone,
I'm currently trying to add a local tiff file to my map like this :
<SPAN class="keyword token">var</SPAN> layer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">ImageryLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"assets/data/rasters/temperature.tiff"</SPAN><SPAN class="punctuation token">,</SPAN>
format<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"tiff"</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"dark-gray-vector"</SPAN><SPAN class="punctuation token">,</SPAN>
layers<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>layer<SPAN class="punctuation token">]</SPAN>
<SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN>
map<SPAN class="punctuation token">:</SPAN> map<SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">100</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">40</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>But it's not working, I got those errors :
<SPAN class="punctuation token">[</SPAN>esri<SPAN class="punctuation token">.</SPAN>layers<SPAN class="punctuation token">.</SPAN>ImageryLayer<SPAN class="punctuation token">]</SPAN> #<SPAN class="token function">load</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> Failed to load layer <SPAN class="punctuation token">(</SPAN>title<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'Layer'</SPAN><SPAN class="punctuation token">,</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'1700a2d2e51-layer-0'</SPAN><SPAN class="punctuation token">)</SPAN> d
<SPAN class="punctuation token">[</SPAN>esri<SPAN class="punctuation token">.</SPAN>views<SPAN class="punctuation token">.</SPAN>LayerViewManager<SPAN class="punctuation token">]</SPAN> Failed to create view <SPAN class="keyword token">for</SPAN> layer <SPAN class="string token">'Layer, id:1700a2d2e51-layer-0'</SPAN> <SPAN class="keyword token">of</SPAN> type <SPAN class="string token">'imagery'</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
I checked some solutions to add my file on the map but none worked. Can someone help me to figure out how to do it ?
