I am trying to reclassify a raster to a single elevation band - and have the rest of the data as NODATA. I am using the below code:
import arcpy
from arcpy import env
import os
overflowvalue = 894
resname = '2965'
minvalue = overflowvalue - 28
maxvalue = overflowvalue - 87
remapString = "{} {} 1".format(maxvalue, minvalue)
env.workspace = "D:\projects\Reservoir\\Data.gdb"
inRaster = 'Elevation'
outraster = 't_{}'.format(resname.replace(" ","_"))
arcpy.CheckOutExtension("3D")
print " - Reclassifying"
arcpy.Reclassify_3d(inRaster,field,remapString,outraster, "NODATA")
Eventually I want to put this in a loop to run it on 45 different overflowvalue elevations. I am getting the following error when running as a stand-alone script:
\projects\Reservoir>test2.py
- Reclassifying
File "D:\projects\Reservoir\test2.py", line 24, in <module>
File "c:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\ddd.py", line 4467
, in Reclassify
raise e
arcgisscripting.ExecuteError: ERROR 999999: Error executing function.
The table was not found. [VAT_t_2965]
No spatial reference exists.
Failed to execute (Reclassify).
Any help would be appreciated - using Python 2.7, ArcGIS 10.5.1
