I am trying to use the 'Map Tour' story map with a 'Feature Layer from my ArcGIS Server.
The issue I am having is that my Feature Layer is not appearing. The REST request is appending on an extent parameter that will never find features.
Extent being requested - why?
<SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"xmin"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">0.000009324401617050171</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymin"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">156543.0339186415</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"xmax"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">156543.0339186415</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymax"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">0.000009324401617050171</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"wkid"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">102100</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"latestWkid"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">3857</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I am referencing it as Layer index 0 in my ArcGIS Online Map and all my data is projected the same.
Below is the URL to my Feature Layer
Layer: WEBLIVE.GIS.SC_TRAILNUMBEREDPOINT (ID: 0)
Any ideas what is happening?
Thanks in advanced,
Drew
