I need to use per replica sync model with ArcGIS server, but the service's Supports PerReplica Sync: false. How do I enable it?
The Supports PerLayer Sync is true for all services.
ESRI's documentation only says this (it doesn't describe what needs to be done to enable it):
supportsPerReplicaSync will be true if the layers can be synchronized together, and the service will accept a value of perReplica for the sync model during the createReplica operation. If supportsPerReplicaSync is false, then the only sync model supported is perLayer. Only present if syncEnabled is true.
Also, how do I know when "the layers can be synchronized togeter"? Is there a setting/a state which defines it?
We need this for the offline sync to work with ArcGIS Runtime Desktop API for Microsoft .Net (10.2.4.0).
