Using these instructions, I have added a Set Data Source button to my main tool bar for ArcMap. The button, however, is grayed-out and I can't seem to find what would cause this so I can fix it. Advice would be gratefully received. I am running 10.3.1. Thanks much.
Based on the help page and process you included in you post, it looks like that tool requires the Defense Mapping Extension. Do yo have that extension?
If not, there are other ways to update data sources...
IF by chance you DO have the Defense Mapping extension, it may just be you have not installed or activated it. I do not have the extension, so not sure the way to do that (and didn't have luck finding a simple help page for it), but it may be a matter of selecting it under Customize->Extensions.
William...This is the place for help about GeoNet GeoNet Community Structure
I have moved this to Managing Data to attract a wider audience
As a check, do you have a layer selected when you active this option? or the dataframe's name/
I do have layers selected as shown in the screen grab below. Thank you very much for putting my question in the right slot. I'm still not entirely sure how to work GeoNet and it shows.
Ok... you have the title of the table of contents selected... not one of the layers underneath
This happens because ArcMap is not able to find the data source i.e it is the case of broken data link.
See this;
Repairing broken data links—Help | ArcGIS for Desktop
If the layer is a part of a basemap layer, you won't get the option of setting the data source. Copy the layer outside the basemap layer, change the data source of the independent layer, and replace it back to the basemap layer.
Rebecca, thanks very much for the information. There are so many ways to do the same thing in ArcGIS, that for those of us who don't do this full-time, confusion sometimes sets in. I have managed to get my overarching problem solved and now have some time to refine an approach and learn a bit more about how to do things more elegantly and with less effort. It was kind of you to spend time preparing an answer.
Glad to help. You are correct, always more than one way to do things, and I probably missed one too. But glad you were able to resolve your immediate issue.
Don't forget to mark this thread as answered.
