Hello There,
I installed and configure ArcGIS Monitor on a server. I was able to successfully authorized the application by 30 days trial license provided by local Esri distributor.
When i tried to launch ArcGIS Monitor Administrator, it failed to launch displaying a pop up 'Feature arcsysmon not authorized'.
Kindly suggest.
Environment:
Windows Server 2012 R2
ArcGIS Server & Portal are not on this server.
Error(attached)
-AS
I got reply from Esri Saudi Arabia which resolved the issue.
Kindly proceed with the steps mentioned below:
--AS
Hello Abdullah Saleh,
Please contact tech support to resolve your license issue. Thanks!
Did you get a resolution on this? I am experiencing the same issue. If I can save myself a tech support call that would be nice.
Hi Shaun,
I suggest contacting Tech Support about this so they can check if the issue is the authorization file.
Best Regards,
John
