Original User: ionara_wilsonI have a model that an ESRI associate sent me as an example. When I run the model everything is great. But I need to have it as a script so I converted it to a script and set the Selecting Features parameter to be a "Feature Set" and have a schema of a polygon layer. However when I convert this model to a script and try to run as a script, I get an error saying it cannot find the EditField. However the EditField should have been copied to the layer in the Make Feature Layer process. It is not clear why it cannot find the EditField ! Any help?The first picture shows the model, the second shows the model when I run it, the third shows the error I get, and the fourth shows the parameters I set before I run the tool. Thank you!!![ATTACH=CONFIG]27890[/ATTACH][ATTACH=CONFIG]27891[/ATTACH][ATTACH=CONFIG]27892[/ATTACH][ATTACH=CONFIG]27893[/ATTACH]# -*- coding: utf-8 -*- # --------------------------------------------------------------------------- # calcfeatures_script.py # Created on: 2013-09-30 15:22:46.00000 # (generated by ArcGIS/ModelBuilder) # Usage: calcfeatures_script <Selecting_Features> <value> # Description: # test # --------------------------------------------------------------------------- # Import arcpy module import arcpy # Script arguments Selecting_Features = arcpy.GetParameterAsText(0) if Selecting_Features == '#' or not Selecting_Features: Selecting_Features = "in_memory\\{1CFDCCDD-5D8D-42F8-AEB2-E66ED4A51A44}" # provide a default value if unspecified value = arcpy.GetParameterAsText(1) # Local variables: Input_Points = "D:\\ArcGISData\\ESRI_GEO_EX\\GDB.gdb\\SamplePoints" Final_Output = value Selected_Features = Selecting_Features Input_Points_Layer = "SamplePoints_Layer" # Process: Make Feature Layer arcpy.MakeFeatureLayer_management(Input_Points, Input_Points_Layer, "", "", "OBJECTID OBJECTID VISIBLE NONE;SymbologyField SymbologyField VISIBLE NONE;DomainField DomainField VISIBLE NONE;Shape Shape VISIBLE NONE;Subtype Subtype VISIBLE NONE;EditField EditField VISIBLE NONE") # Process: Select Layer By Location arcpy.SelectLayerByLocation_management(Input_Points_Layer, "INTERSECT", Selecting_Features, "", "NEW_SELECTION") # Process: Calculate Field arcpy.CalculateField_management(Selected_Features, "EditField", "'%value%'", "PYTHON_9.3", "")
