I've successfully managed to create new polygon features in a featurelayer using sketch geometries applyEdits() when the user finishes drawing. This, however, has some issues from a usability point of view - in that if my user has made a mistake they cannot edit the polygon before the rest of the form on the page is submitted.
What I'd like to do is either
a) submit the polygon when the page on the form is submitted (preferable), or;
b) work out how to delete the polygon from the feature service using the drawing that's still on the screen
The function I am successfully using:
<SPAN class="comment token">// Listen to create-complete event to add a newly created graphic to view</SPAN>
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"create-complete"</SPAN><SPAN class="punctuation token">,</SPAN> addGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// Listen the sketchViewModel's update-complete and update-cancel events</SPAN>
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"update-complete"</SPAN><SPAN class="punctuation token">,</SPAN> updateGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"update-cancel"</SPAN><SPAN class="punctuation token">,</SPAN> updateGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// called when sketchViewModel's create-complete event is fired.</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">addGraphic</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// Create a new graphic and set its geometry to</SPAN>
<SPAN class="comment token">// `create-complete` event geometry.</SPAN>
<SPAN class="keyword token">var</SPAN> varCreatedByUser <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#Created_By'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> varCreatedDate <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#Upload_Date'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> varActivityType <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#Activity_Type'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> varActivityName <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#ActivityName'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> varOCBYear <SPAN class="operator token">=</SPAN> document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">querySelector</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'#Year'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> event<SPAN class="punctuation token">.</SPAN>geometry<SPAN class="punctuation token">,</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>symbol<SPAN class="punctuation token">,</SPAN>
attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
CreatedByUser<SPAN class="punctuation token">:</SPAN> varCreatedByUser<SPAN class="punctuation token">,</SPAN>
CreatedDate<SPAN class="punctuation token">:</SPAN> varCreatedDate<SPAN class="punctuation token">,</SPAN>
ActivityType<SPAN class="punctuation token">:</SPAN> varActivityType<SPAN class="punctuation token">,</SPAN>
ActivityName<SPAN class="punctuation token">:</SPAN> varActivityName<SPAN class="punctuation token">,</SPAN>
OCBYear<SPAN class="punctuation token">:</SPAN> varOCBYear
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
graphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> edits <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">//Fire the addFeatures function using the completed graphic</SPAN>
addFeatures<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>graphic<SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>currentSketch<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">applyEdits</SPAN><SPAN class="punctuation token">(</SPAN>edits<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"polygonButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>disabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//disable new feature button to prevent duplicates</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>What I have tried so far:
Option a)
Watching my form submit button for an onclick action and attempting to grab the graphic in the same way that the function addGraphic(event) function does. Not sure if this is a great idea as I'm also sending a form that causes a page change..
I assume this one fails because I'm not passing the object in via the event, though I'm not really sure.
<SPAN class="comment token">//Try to catch the form submit function</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"btnFormSubmit"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>onclick <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//graphicsLayer.add(graphic)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Option b)
I also tried for option b) by allowing the graphic to be submitted and then allowing the user to delete the feature and start again. I suspect I'm missing quite a bit here - like I'm sure I probably need to be collecting the object ID of the feature from the server after submission, storing that in a global variable, and then on delete passing that Object ID back + clear the map. I'm just not sure how, and I have not found a reference to this that seems like it would work. I've also tried referencing deleteFeatures: [graphic], but I'm assuming it's out of scope since its created in the create function. I'm not really sure about that being the right line of thought either.
<SPAN class="comment token">// *****************************************************</SPAN>
<SPAN class="comment token">// Delete button click event. ApplyEdits is called</SPAN>
<SPAN class="comment token">// with the selected feature to be deleted.</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"btnDelete"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>onclick <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">// setup the applyEdits parameter with deletes.</SPAN>
deleteFeatures<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>editFeature<SPAN class="punctuation token">]</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>editFeature<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
document<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getElementById</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"polygonButton"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>enabled <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//disable new feature button to prevent duplicates</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any ideas?
Thanks in advance
