I have point data that is being collected using Survey123 and I would like to use the Calculate Density analysis tool to get a density plot of the points. I'm using the defaults and have my map zoomed so that the data I am interested in is displaying on the map. Every time I run the Calculate Density tool in ArcGIS Online it churns for a few minutes and then throws up an error message: "CalculateDensity failed".
Has anyone else ever seen this error before? Any ideas what is causing the problem?
Thanks in advance,
It turns out the problem was that the feature layer I was trying to run Density Analysis on was a view layer.
