Data Reviewer Support Group
Hi, I am new to Data Reviewer and to Water Utilities. I have configured the automated batch checks successfully. I am assessing the flagged errors but I am not sure why the Butterfly valve less than 24 inches in diameter for Water is part of the check. Any explanation will be appreciated. Thank you.
The checks that were defined for the water utilities were based on input from the Solution Engineers here at Esri. You are not the first person to point out the diameter threshold for Butterfly valves. I'm not a water expert so, what is a typical minimal diameter of a Butterfly valve? I'm planning to review several of the Data Reviewer templates for the different industries to make updates and enhancements. I'll take a note of this.
BTW, you can modify the check properties to change that to a different size in Batch Job Manager.
Thanks for your comment.
michellej.
